Histogram data format
Forum_2015
Post by Forum_2015 »
Hi all,
How I can save a histogram data format. I basically need two columns: ADU and COUNT.
Grazie.
Paolo
Forum_2015
Re: Histogram data format
I think that there is no way to save them. By the way, if you are a programmer you could do it as a plugin. It should be an easy task, probably 1-2 hours of work, starting from the template in the SDK.
Forum_2015
Grazie Fabio,
I will work on the plugin in the winter, when I have a little more time!
Forum_2015
Edit:
this feature has been added to Astroart 6, in the context menu of the histogram window: "Save as text"
