Astroart 6 not saving 16 bit tiff format
Forum_2016
Post by Forum_2016 »
Does anyone else have the same problem ??? When I save view in AA6 I select save as 16 bit Tiff format. However, when I then open it in Photoshop it says it's 8 Bit.......does anyone know what's going on
Forum_2016
Re: Astroart 6 not saving 16 bit tiff format
I don't usually save to tiff so I just tried it and it is 16 bit in PhotoShop?
Forum_2016
Hmmmm that's strange because when I go to mode in Photoshop it always shows it as an 8 bit
Forum_2016
I think that save as is the proper way to save 16 bit tiff (not view).
Forum_2016
Thanks I'll give that a go. If that is the case though, it means you can't do any preprocessing in astroart to then go on to process in Photoshop. Any curve stretches etc are not saved if you just save normal without saving view mode.....or am I missing something here
