Fuji RAW images
Fuji RAW images
Has anyone used Astroart to stack Fuji DSLR *.raf RAW images?
Re: Fuji RAW images
I haven't, but you should be able to test it with the free demo version if you don't already have Astroart.
Re: Fuji RAW images
Partially. Which model? In the latest models (for example: X-T20) the format is changed and it's not supported by dcraw. In previous models (for example: X-Pro2) images can be opened but the X-Trans CCD is not supported for debayering:
https://en.wikipedia.org/wiki/Fujifilm_X-Trans_sensor
So the only way to stack these image is to open them with the option "dcraw demosaic on load" (Preferences), but doing that it's not possible to correct the dark frame before demosaicing.
