Opening AA6 created FITS in Pixinsight - doesn't read
Forum_2018
Post by Forum_2018 »
hi, I created some FITS files when processing in AA6. A friend wanted to process in Pixinsight but reports that PI doesn't recognise the files - at least they open in PI but there's no apparent data. I tried this myself and can verify the issue.
The FITS header details in attached
Forum_2018
Re: Opening AA6 created FITS in Pixinsight - doesn't read
I think it's in 32-bit
If I save as PNG-FITs and open in PI it is read ok....so not sure what's going on
Forum_2018
Hello, Google: pixinsight 32 bit fits
If you want to change the file format, you may use 32 bit floating point, which is a more common format: in AA Menu Edit / Data format / Floating point. Then save again.
Forum_2018
thanks for quick response Fabio - will try that
