Hallo,
I use AA7 (coming from AA6-5-4-3) with a QHY10 camera connected via ASCOM using the "image rotate 90°" option, it worked great since yesterday. I made a mistake trying to connect the camera with the USB cable unplugged and I got a system warning. Plugged-in the USB cable the camera connection was done us usual, but any image downloaded is a wrong one. Landscape shape but grey for 2/3 (roughly 2000 ADU) and 1/3 completely black. If I cancel the "image rotate 90°" option everything turns back to be fine but in portrait shape. Furthermore using AA6+ASCOM, still installed in my PC, everything works properly with the "image rotate 90°" option ON and OFF.
It seems something has been corrupted in AA7 and I can't solve the problem even uninstalling and reinstalling AA7: the problem is still there.
In the mean time AA6 works but it will be great to have suggestion to solve the problem in AA7. Thanks.
Emilio
ASCOM Image rotate problem
Re: ASCOM Image rotate problem
update: the problem is present using a new PC-WIN10 with a fresh AA7 install, not depending on USB cable mistake.
I suggest to open Astroart 6 and 7 side by side and verify if they have the same ASCOM plugin (last should be 2.10) and same options.
However I suggest to solve this way: instead of using the Rotate 90° function of the ASCOM plugin, use the Rotate 90° function of the new Camera Control 7.0, inside its "Options" window: tab "Images" / "Flip and Rotate".
ASCOM plugins and options are the same both for Astroart 6 and 7, I can't explain the different behaviour. However the Rotate 90° option included in Camera Control 7.0 solve the problem and that's what i need. Thanks for your support.
Emilio
Emilio
