Saving of sub frame focus window
pscheuter
Post by pscheuter » 24 May 2019, 14:27
Is there a way to save the image in fits format that is generated in the focus window? I would like to use CCD inspector defocus star collimate routine but it needs a directory to read the fits image. CCD inspector will delete the image after it reads it. This will prevent hundreds of saved frames.
peter
Re: Saving of sub frame focus window
Post by fabdev » 24 May 2019, 15:44
not from the focus window, but you could do this way:
after you have selected the rectangle used for focus, go to the Setting page and click "Subframe / From selection", then you can start a Sequence with autosave which will do the job. Remember to set the same short exposure time.
Greetings,
pscheuter
Post by pscheuter » 24 May 2019, 17:43
Thank you, I will give it a shot tonight.
peter
