LAA version of AA6
cjacobson
LAA version of AA6
Post by cjacobson » 03 Oct 2019, 23:29
Iam trying a new camera, ASI 1071 mc pro. As I try to center an object after ten frames I get the following error message: out of memory use LAA Version of AA. What is this? I have never received this before using one of my starlight xpress cameras. Thanks Cjacobson
Re: LAA version of AA6
Post by fabdev » 04 Oct 2019, 11:08
Hello, the LAA version is installed in your PC, the link is the Start menu of Windows, or you may create a new Icon for it on the Windows desktop, picking the file from the Astroart installation folder.
At 6000x4000 pixels you cannot have more than 10 windows opened at the same time with the standard version, but with LAA you will reach 20. For test images you may disable the option "New window". Or, just for centering binning is recommended.
About LAA see: Glossary in the Help.
The following diagram is for AA7 but it's valid for AA6 too (without the 64 bit version)
cjacobson
Post by cjacobson » 04 Oct 2019, 18:09
Thanks Fabio. cjacobson
