Profile line: Strange behavior
Post by AstroBernd » 29 Dec 2020, 10:52
When using the "Profile Mode", i am sometimes seeing a strange behavior when updating the profile:
In Profile Mode, after drawing a line with the cursor across the whole image from upper left to lower right (example attached),
The attachment Profile error 1.png is no longer available
when clicking "Change Profile", the profile resets to a smaller line near the middle of the image from lower left to upper right. This line always has the same coordinates: It seems it is only happening when i draw the line (second point) well across the limits of the original image. It is NOT happening when using the menu/View/Free command or <<ctrl-L>>.
Anybody else seeing this behavior?
Take care
Re: Profile line: Strange behavior
Post by fabdev » 29 Dec 2020, 18:53
Hello, I confirm that if the second point is outside the image then the "Change profile" function does not work. It will be fixed in Service Pack 6. For the moment the only solution is to limit the line inside the borders of the image.
Thanks, Fabio.
Post by AstroBernd » 30 Dec 2020, 17:32
Thanks Fabio,
Looking forward to the fix.
