AllCometEls.txt vs CometEls.txt
Post by Dunmunro » 21 Jan 2023, 21:35
I guess the Minor planet Center must have renamed the comets file at some point. Anyways I have to remove the 'All' from the AllCometEls.txt file to get AA8 to read it.
https://minorplanetcenter.net//iau/MPCORB.html
Re: AllCometEls.txt vs CometEls.txt
Post by fabdev » 22 Jan 2023, 15:17
It must be happened in the last 3-4 days. That would cause trouble to a lot of software.
For the moment the only solution is to rename the file after the download.
Thanks, Fabio.
bill
Post by bill » 01 Feb 2023, 21:49
If you still want to use the smaller truncated data file CometsEls.txt (971 entries) it's available here; https://www.minorplanetcenter.net/iau/M ... metEls.txt
The AllCometsEls.txt data file currently has 4,576 entries.
Bill
