Pause PHD2 when FF AF?
Re: Pause PHD2 when FF AF?
Hello, the "settling" state should be "Looping". But you don't need to check for it, just check until the status is "Guiding".
Center script command, also from help file.
Telescope.AutoCenter(exposure, binning, [ra,dec])
Starts the automatic centering with plate solving, using the new Centering Window of Astroart 8 SP1. The script will be paused until the procedure is complete, then use the function: Telescope.AutoCenterOK() to verify the result.
Thanks Fabio and Iver. Once I have completed my script and tested it, I will share it here on forum.
The idea is to be create a mosaic in the atlas, and then "copy for telescope list" and paste that into the script, which will then run a sequence on each panel.
@fabio: the "copy for telescope list" generates a list like this:
Have you considered making the tile names reflect the tile positions in stead of beeing sequentiel? For example:
That would make it simpler to assemble large mosaics later on, if the tile names are used to generate file names.
"M1" 00 41 07.9 +41 02 50
"M2" 00 41 07.6 +41 16 07
"M3" 00 41 07.3 +41 29 25
"M4" 00 42 44.9 +41 02 53
"M5" 00 42 44.9 +41 16 10
"M6" 00 42 44.9 +41 29 27
"M7" 00 44 21.9 +41 02 50
"M8" 00 44 22.2 +41 16 07
"M9" 00 44 22.6 +41 29 25
"Tile_001_001"
"Tile_001_002"
"Tile_001_003"
"Tile_002_001"
"Tile_002_002"
"Tile_002_003"
"Tile_003_001"
"Tile_003_002"
"Tile_003_003"
OK, it will be improved for AA8 SP2, available in september-october.
Thanks, Fabio.
Thanks, Fabio.
Any news on pausing PHD2 when doing an auto focus in a sequence?
PHD2 still "freakes out" when I auto focus. I am using an off axis guider.
I know I can script my way out of it, but it would be very convenient to have a checkbox in the sequencer: Pause PHD2 when AF.
Hi Rudi, just a suggestion. I really like the idea of the sequencer. A few times I requested new features to Fabio and he implemented some of them. Since the sequencer will create a script that will do the same thing I have found it much easier to embellish the script whenever I feel the need for a new task. Just a couple of examples, when the sequence is complete the script checks the AstroArt telescope goto list. If I have put a second target there it does a goto solve and center and runs the sequence, I can put as many targets as I like. Once there is no target the script parks the scope and shuts the power off. Once I get my observatory built I plan to add a close roof script between the park and power off. With scripting the sky is the limit.
The sequencer will never be as flexible.
