guide with sac7
Forum_2016
guide with sac7
Post by Forum_2016 »
Hello, I try to reinstall my old equipment. I downloaded AA6 I use a modified webcam SAC7, I downloaded and installed the drivers d_modcam gwiopm. when I want to connect the webcam software told me that the driver is busy. I tried several times by stopping and restarting the PC: none. what is surprising is that with Maxim dl demo it find without problem the camera! ??? Thank you for your help
Claude
Forum_2016
Re: guide with sac7
Hello, the parallel port driver may not work anymore on latest Windows (but you could try executing Astroart in Administrator mode). If your modified webcam uses signals from the parallel port, it may be no longer possible to trigger long exposures (verify this with Maxim).
Meanwhile, you could test the camera connection using the "VIDEO" driver instead of the "MODCAM" one.
Forum_2016
Re: guide with sac7
hello, the video driver works but is autoguiding possible with the video driver?
Forum_2016
Re: guide with sac7
Hello, if the camera has an integrated ST4 autoguide port, it won't be controlled by the Video driver.
If not, you can still autoguide with other connections. I suggest to set the lowest frame rate in the Video driver (for example 5 fps), then if you set an autoguide exposure time of 1 second, five frames will be automatically added into a single image. This will give you 10 bits of dynamic instead of 8 bits.
Forum_2016
Re: guide with sac7
Thanks for this information Fabio! My QHY-5 has a video driver, maybe the 10 bit range will ease the issue I was asking you about.
