Nikon D810 and D810A - two camera control
Post by Dunmunro » 28 Feb 2019, 01:09
I have tested the Nikon 1.10 driver and I can control a D810 and a D810A simultaneously using two instances of AA7 32bit (non LAA). I had an ASI 120mm mini using ASCOM running in instance one at the same time.
Re: Nikon D810 and D810A - two camera control
Post by fabdev » 28 Feb 2019, 02:32
Thanks, may you test with LAA too?
For 20+ megapixels DSLRs, LAA can be useful.
Post by Dunmunro » 28 Feb 2019, 03:31
fabdev wrote:
28 Feb 2019, 02:32
You're welcome.
I'll try the LAA version tomorrow.
Post by Dunmunro » 03 Mar 2019, 01:41
OK. I tried the LAA version of AA7 and connected the D810A as camera 1 in AA7 instance 1 and the D810 as camera 2 in instance 2 and it worked fine in test mode, with both cameras exposing simultaneously.
Post by Dunmunro » 20 Mar 2019, 19:53
Would it be possible to add D800 and D800E support to the driver?
I'd be happy to test it ASAP.
thanks
Post by fabdev » 20 Mar 2019, 21:28
Hello, OK, I will try to make a version for it. Please write me by PM or email.
Post by Dunmunro » 22 Mar 2019, 15:18
The Nikon D800 and D800E were successfully tested with the modified Nikon 1.1 driver.
thanks Fabio.
