flat frames problem
maplearn
flat frames problem
Post by maplearn » 17 Jan 2021, 09:24
Trying to take flats and they are split in the middle with different shades. Can someone help? No problem with the camera, takes proper flats with other software.
maplearn
Re: flat frames problem
Post by maplearn » 17 Jan 2021, 12:26
figured it out. the guide camera is confusing the software. I installed two separate ZWO camera for photos and guiding. The software senses them correctly but but the image is mixing the two. Actually I had the same problem with other software including ZWO's own software, ASI. Has anyone else had this problem and resolved it?
Ernie
Post by Iver » 17 Jan 2021, 21:01
This happens even if you select the imaging camera as 1 and the guider as 2 ?
maplearn
Post by maplearn » 17 Jan 2021, 22:50
yes
Post by fabdev » 18 Jan 2021, 14:21
Only an updated ASI ASCOM driver could solve the problem. Maybe it's fixed yet, verify the latest version on the ASI web site. Some months ago there was a discussion about this also on the ASI forum.
Some hints by the way: don't use a USB hub, connect the two cameras in a given order, both physically and by software. Just a try.
