Back to the same issue I had before with this exception. AA9 thinks I am using a Zwo asi 071mc pro and not the 2600mc pro. I initialize the camera by clicking ASCOM and follow the routine that I have done before. the software thinks I have tried to use the 071. I have that camera but it has never been used on this machine. I click AScom and the next module says ASCom, ASIcamera2.camera. Click on connect and I see it thinks this is the 071. Recently it also confused my asi guide camera and placed it in this setting as well. Im using AA9 LLA. I tried the 32 and 64 with the same thing. this is on a W11 machine.
If I connect via the 071 configuration and try to produce an image I get a black screen with static. thanks charles jacobson
AA9 and ASI 2600 071
Re: AA9 and ASI 2600 071
In the Camera control you should have "ASCOM" selected in the main camera field. Then when you hit Set Up you should have "Choose camera on Connect" selected. When the chooser window opens you should have ASI camera 1 in the drop down. Then when you hit properties do you see the 2600 MC pro ?
