creating Hubble palette
Forum_2016
Post by Forum_2016 »
Hi I am tring to obtain the tipycal hubble palette of a narrow image of the cygnus wall but I don't get the the amber and blue hues.Is there a tutorial, can somebody help me?
Thank you
Roberto
Forum_2016
Re: creating Hubble palette
Thank you, but I would like to have the tutorial for astaroart
Ciao
Post by Rudi » 29 Oct 2019, 08:09
Did You find out about this @Roberto ?
I am trying the same with AA7.
Post by Rudi » 29 Oct 2019, 09:21
I found this Youtube video:
https://www.youtube.com/watch?v=bNUFobiCCIw
The trick is to use the Ha and OIII images as follows in Trichomy:
Red: Ha
Green: OIII
Blue: Ha
Post by fabdev » 29 Oct 2019, 14:49
Also, if you need to create the frame which is 70% HA and 30% OIII , it's possible to use the "Merge" Window or the "Average" Window, after having aligned the images with the command "Align" or "Align All".
Post by Rudi » 29 Oct 2019, 16:04
I tried both the above methods, but I wasn't pleased with the result. Then I "stumbled" over a thread on stargazers lounge, can't re-find it, unfortunately, where someone mentioned, that in the case of H-alpha and O-III, one needs to create a "synthetic" green channel, by multiplying H-alpha with O-III.
This worked for me:
Given is two images, "Ha" and "OIII".
1) Open "Ha" and use DDP to stretch.
2) Open "OIII" and use DDP to stretch.
3) Select "Ha" and press F2 to mak a copy.
4) Select menu item Arithmetic->Multiply and choose "OIII". This multiplies "Ha" with "OIII".
5) Use DDP to stretch the result and save as "Ha_multi_OIII"
6) Trichromy:
Red : "Ha"
Green: "Ha_multi_OIII"
Blue: "OIII"
Algorithm: White point
I just used the above technique on the Fish Head.
Full resolution:
https://www.dropbox.com/s/skz5ioot8v7o3 ... .jpg?raw=1
