Hot Pixel Process - Might this change be considered for future versions?
Forum_2016
Post by Forum_2016 »
Concerning the 'One Pixel Defects' option.
As previously advised, for a pixel to be considered 'single', it must be the only pixel in a 3 x 3 square.
Might a user choosing the 'One Pixel Defects' selection also then be given an option to discard one pixel value of the surrounding 8 when calculating the replacement value?
This should be for the first pixel classified as hot (assuming that there is a processing sequence). This might then allow a "discarded" pixel to also be corrected.
My thoughts.
Patrick.
Forum_2016
Re: Hot Pixel Process - Might this change be considered for future versions?
the other option "group of pixels" should address those cases. By the way, I think that the best way to do that is to evaluate every algorithm on a set of images, analyzing also if/how it changes the brightest pixel of some stars (it must not happen obviously). You could do it with the demo plugin in the SDK, it just reads a 3x3 pixel window, process and write the pixel. You only need to change the algorithm.
Kindest regards,
Forum_2016
Thanks for that - I am not a programmer.
Patrick.
