Bayer
Morten Lerager
Bayer
Post by Morten Lerager » 10 Oct 2021, 08:38
Hi'
First post. Until now i have been using Siril.
My setup is HEQ5 Pro with SW 150PDS/ f5. 60mm guide cam
Main cam DSLR eos 2000D guide system Lacerta
Now trying AA8 hopeful :)
I'am not sure to set Debayer right when preprocess. When i process in Siril i get a log saying the format is GBRG
Canon 2000D
More here https://www.libraw.org/node/2603 (I don't know if AA are using libraw)
And inside PI https://pixinsight.com/forum/index.php? ... cut.13249/
So which mode should i choose ?
Morten Lerager
Asi294mc. AA8.
Re: Bayer
Post by Dunmunro » 10 Oct 2021, 17:40
Morten Lerager wrote:
10 Oct 2021, 08:38
Hi'
Canon 2000D
Morten Lerager
I find the quickest way to decide which pattern to use it to test the output with an image of M42; the correct choice is easily recognized. You could also image a terrestrial test target to see which is the best match.
Morten Lerager
Re: Bayer
Post by Morten Lerager » 10 Oct 2021, 19:45
Thank you
Oki I hope to find my lens, and try a terrestrial test.
I was hoping AA had some auto recognition like others.
Asi294mc. AA8.
Re: Bayer
Post by fabdev » 10 Oct 2021, 21:19
Hi, to auto-recognize the pattern there's also the button "Open <firstfile>" in that dialog window, the button becomes visible once some files are selected in the Images box. At the moment there is no recognition (25% 25% 25% 25%) because no images were opened from disk. Once that is done, probably the third value will be highlited for the EOS 2000.
The setting will be remembered for future preprocessings.
