Hi
I would like to blink align three images from file. I need to open the files, align all three. I then need to repeat.
Any advice on this?
Blink align 3 images
Re: Blink align 3 images
Hi, a script command for blinking three images does not exist, but you may use a semi-automatic script.
Using a cycle, your script should:
1) open the three shots of the image #1
2) pause(999) to pause the script
Now you click on Blink 3 and the autoalign button to inspect the images.
When you are done, you close the blink window and click the Run button of the script window to skip the pause.
3) The script continues closing the three images
4) The script select the image #2 and repeats
