Hi Fabio
I was wondering if there was any possibility of a 64bit AARemote.dll? I might have missed it, but it looks like the only download option is 32bit.
Cheers,
Andrew.
AARemote 64bit?
Re: AARemote 64bit?
Hi Andrew,
at the moment it's not available, but I guess that I could recompile it easily as 64 bit.
By the way, the 32 bit DLL works well under Windows 64. It doesn't work only if your client software is compiled for 64 bit.
Is this the case? Which compiler?
Re: AARemote 64bit?
Unfortunately my host "language" is 64bit only. Worst case I can write a small comms layer for AARemote and run it in a stand-alone 32bit process. However, if it is not too much trouble to build me a 64bit AARemote that would be far preferable.
Cheers,
Andrew.
Cheers,
Andrew.
Re: AARemote 64bit?
Works perfectly! Thanks Fabio.
