Hallo,
I am facing a problem using the Camera.Connect, Guider.Connect, Telescope.Connect commands whenever used via a button graphic menu.
The following is the script I used as a test inside the simulator environment:
conn$=""
butconnect=InputButton("Connect"+Conn$,"Cam1","Cam 2","Telescope","End")
while butconnect<>"End"
if butconnect="Cam1" Then
Camera.Connect
Conn$=": Cam1 OK"
endif
if butconnect="Cam2" Then
Guider.Connect
Conn$=": Cam2 OK"
endif
if butconnect="Telescope" Then
Telescope.Connect
Conn$=": Telescope OK"
endif
endwhile
end
Running the script the "End" button works normally, but selecting Cam1 or Cam2 or Telescope the requested connection is done but the script freezes and the button menu does not appear anymore.
What i am doing wrong?
Emilio
Camera connect
Re: Camera connect
Hallo,
InputButton should be inside the loop, so:
conn$ = ""
butconnect = ""
while butconnect <> "End"
butconnect = InputButton("Connect"+Conn$, "Cam1", "Cam 2", "Telescope", "End")
conn$ = ""
butconnect = ""
