Automation of meridian flip
jauunton
Post by jauunton » 08 Sep 2021, 03:27
Hi all,
I am looking for a way to automate imaging sessions when the target crosses the meridian.
What I need to happen is the sequence/script detects the flip starting, stops the guider, waits for the slew to complete, takes a test shot, plate solves, re-centers the target, restarts guiding, waits for a settle and then re-starts the imaging sequence. Anybody done this? I use PHD2 for guiding but can use the AA guiding routines if that makes things easier.
Regards
Re: Automation of meridian flip
Post by Iver » 08 Sep 2021, 16:32
For flip detection you could use "Guider.LostStar" in your imaging script. If it returns True then have the script go to a sub script that starts with a pause long enough to be sure the flip has completed. Then takes an image, solve and sync to the image and GoTo your target. re calibrate your guider and start imaging. I've never tried this but it seems like it could work, there are script commands for all the tasks.
Good luck!
Post by fabdev » 09 Sep 2021, 16:00
To detect the current side of the mount, for ASCOM telescopes, it will be released (but it's already included in AA7) the script function:
Telescope.PierSide
which returns 0, 1, -1 following the ASCOM standard:
https://ascom-standards.org/Help/Platfo ... erSide.htm
Just try:
Print Telescope.PierSide
jauunton
Post by jauunton » 09 Sep 2021, 22:52
Thanks...I have AA7 so I will try that....
Deapsky
Post by Deapsky » 01 Jan 2022, 12:14
Hello AA users,
here are some simple routines to find out if a flip is necessary or not:
azlimit ist the limits where my mount can go without a flip.
The telescope give back it RA and DEC position, together with the position of observation I can calculate the azimut position.
RA=Telescope.RA
DEC=Telescope.DEC
azlimit_east= 170
azlimit_west= 190
lon= 6.75
lat = 51.5
az,al = EquatToAltaz(ra,dec,lon,lat)
Print RA;" ";DEC
Print lon;" ";lat
Print az;" ";al
pierside=telescope.pierside
Print Pierside
Print (az-azlimit_east)
If (az-azlimit_east) > 0 and (az < 180) then print ("Flip --> West possible")
IF (az-azlimit_east) < 0 and (az < 180) then print ("noFlip --> West")
If (azlimit_West-AZ) > 0 and (az > 180) then print ("Flip --> East possible")
IF (azlimit_West-AZ) < 0 and (az > 180) then print ("noFlip --> East")
Hope it is useful
Clear skies
Peter
