Preprocessing - Save/Load Session
Forum_2016
Post by Forum_2016 »
A really nice new feature would be the ability to save/restore preprocessing 'sessions'. By this I mean a snapshot of the form is saved under a user defined name and later can be loaded back in. This would be ideal for projects that require a different set of options, e.g., DSLR vs CCD image processing. All of the parameters on the Files, Options and Extras tabs would be saved in the session file. In addition, if 'session restore' could be added to the script function then it would remove the need to dynamically change settings in the preprocessing function, but would still need the ability to set files.
Forum_2016
Re: Preprocessing - Save/Load Session
Thank you for the suggestion.
At the moment only the file list is saved, in the "recent" box of the Files page.
