Preprocessing command
Craig
Post by Craig » 06 Jul 2021, 18:38
Is there a script command for preprocessing? I didn't see anything in the documentation but there was reference to an experimental version back in 2017 I think.
Craig
Re: Preprocessing command
Post by Iver » 07 Jul 2021, 02:15
I'm not aware of a processing command. You could definitely script some of your processing using the image, star, masking commands and the macro script command.
Craig
Post by Craig » 07 Jul 2021, 10:14
I saw it used in a couple of scripts while searching the posts. Does that mean it has been removed?
Post by fabdev » 07 Jul 2021, 19:25
It's still an experimental command, but it works with AA7. It's not easy to use by the way, you need to build at runtime a text with all the details of preprocessing:
viewtopic.php?f=5&t=293
(the "$" is no longer required for strings)
From the Preprocessing Window, save a preprocessing, then open it into a text editor: this will give an idea about the text to be built at runtime.
