I saw in other posts that the 64bit version of AA is used for image processing only, which means the camera control plugin cannot be used. But that also means I cannot run scripts. Is there any other way to run scripts other than from a camera control plugin?
Craig
64bit running image processing script
Re: 64bit running image processing script
Hi, in a future upgrade the scripts will be separated from camera control to allow that. If you like to use a now a modified version where this is already possible, just write me by email or PM.
