RGB stacks clipping blackpoint
woldsstargazer
Post by woldsstargazer » 25 Aug 2022, 20:23
My RGB stacks in Astroart have started to clip the blackpoint prior to any processing.
Luminance stacks are fine. Trying to understand what the issue is. Any suggestions welcome.
Re: RGB stacks clipping blackpoint
Post by fabdev » 26 Aug 2022, 21:07
Hello, verify if the dark frames are the correct ones (duration, temperature) of each R,G,B sequence.
As a test, try disabling the option "Remove negative pixels" in Preprocessing.
woldsstargazer
Post by woldsstargazer » 28 Aug 2022, 18:01
Thanks for the negative pixels tip. Will try that. Darks all matched ok.
