Astroart 8 SP2
Astroart 8 SP2
Post by fabdev » 19 Sep 2022, 16:50
Hello, a new minor version of Astroart 8 is available:
https://www.msb-astroart.com/
Version 8.0 SP2 - September 18, 2022
* New feature. Tabbed interface when images are maximized.
* New feature. Scripts can be manually paused.
* New feature. Sequences can be manually paused.
* New feature. Software temperature compensation for focusers.
* New feature. Window for dome monitoring and control.
* New feature. User defined pause for telescope settling.
* New feature. Non-linear distortions for image stacking.
* New feature. Full-frame autoguide can save its images.
* New feature. Several new script commands.
* Improved. Finer zoom-out levels.
* Improved. The size of the N-E marker can be set in the Options.
* Improved. All annotations may have multiple lines of text.
* Improved. More FITS files from space telescopes are supported.
* Improved. The direction of autofocus steps can be chosen.
* Improved. Virtual keypad works with more ASCOM telescopes.
* Improved. The ASCOM Chooser can be skipped for all equipment.
* Bug fix. Option for image flipping was ignored in the autocenter window.
* Bug fix. Telescope syncing to last image did not use the JNow setting.
This is probably the biggest upgrade ever released in a service pack. I will write in the following days further details about the features.
Clear skies, Fabio.
Re: Astroart 8 SP2
Post by Rudi » 20 Sep 2022, 05:04
Thanks Fabio!
Many great new features, looking forward to try it out!
Re: Astroart 8 SP2
Post by Dunmunro » 20 Sep 2022, 18:43
Awesome! Astroart is getting better and better!
nmac
Re: Astroart 8 SP2
Post by nmac » 26 Sep 2022, 12:52
Thank you for the update!
