Low resources error
nmac
Low resources error
Post by nmac » 12 Jul 2024, 12:08
Hi all,
I am trying to stack 268 OSC images (imx585 8mb each image) and I am consistenly having a "Low resources error" during the alignment or on the final stack.
Using Astroart 64 version the process won't surpass 3.2Gb of RAM even with 32Gb of ram on PC.
This happens on Win10 Pro x64 amd Win11 Pro x64 versions. Is there any internal limit on AstroArt keep it from using
available memory? I suppose this would only happen on the 32 bit ou LAA version of AstroArt not the 64bit version.
Regards
Nuno
Re: Low resources error
Post by fabdev » 12 Jul 2024, 14:41
Hi, this usually means that there is not sufficient disk space for some temporary files, for Sigma stacking.
The folder for temporary files can be set in the third page of Preprocessing. Usually it's the default TEMP folder (Users/AppData/Local/Temp), so verify that there's at least 30 Gb free in C: If this does not solve, contact for technical assistance at: https://www.msb-astroart.com/support.htm specifying all the details about this preprocessing.
nmac
Post by nmac » 12 Jul 2024, 15:14
Hi Fabio!
Thanks! That was it, for some reason I had a process eating space on the drive.
I change the TEMP to another drive and it solved the problem,
Regards
Nuno
